Seeking help with C170 and C525 webcam please
Posted: Fri Nov 26, 2021 5:11 am
Hello All
I am seeking help, I am trying to get my PD4 to work with my C525 and C170 web cams.
According to the wiki they are supported.
My set up is PD4 with original 7 inch screen and pluto running 202111200 software.
When I select the test-card by its self it works fine and great TX pictures.
When I select the PI camera it works fine.
But when I depower and unplug the PI Cam and I plug in ether the C170 or C525 separately there is no RF output when I transmit
and the LED on the web cam does not light up.
When plugged in separately I can see the web cams when I push the C920 monitor button .
I have tried different symbol rates but no RF out.
Using putty both the web cams identify ok, attached is the C170 printout and the INFO screen.
What am I doing wrong or are there other settings I need to make somewhere ?
Any help would be greatly appreciated Thanks.
Bruce VK3MN
Bruce VK3MN
