Portsdown 4 Update with "Invert Pi Cam" Option
Posted: Wed Sep 01, 2021 8:20 pm
The latest update to the Portsdown 4 (202109010) introduces an option to invert the transmitted image from the Raspberry Pi Camera for H264 transmissions using a LimeSDR or DATV Express.
This option can be used with cases such as the SmartiPi Touch Pro https://smarticase.com/collections/smar ... -touch-pro where the camera is internal, but is mounted upside down. To select the inversion, go to Menu 3, System Config, Invert Pi Cam.
Note that this inversion only works with Lime and Express H264 transmissions, and does not work for the Pluto (except for DVB-T). 90 degree rotations (as would be useful for the other SmartiPi cases) are NOT possible. Other Pi camera functions (streaming, monitor etc) are not currently inverted by this setting.
Thanks to Colin G4KLB for the idea and for testing.
