Portsdown 4 Update with WebCam Support Improvements
Posted: Wed Aug 25, 2021 9:22 am
I have recently released a Portsdown 4 update (202108162) that introduces support for all 3 versions of the Logitech C920 webcam and provides partial support for the C525 and C930e. It also re-introduces the ability to send a stream from a C920 webcam.
More detail about webcam support and limitations on this Wiki page: https://wiki.batc.org.uk/Portsdown_Webcams
I have also fixed the Pluto EasyCap 16:9 capability that I broke in the last release.
Thanks to G4BVK for loan of yet another C920 example, and to G4KLB and HB9DUG for testing the C930e and the C525.
Please report any new bugs here.
Re: Portsdown 4 Update with WebCam Support Improvements
Posted: Fri Sep 10, 2021 2:25 pm
by KA5BBC
Are we still able to use unsupported device such as the hdmi-CSI interface, USB HDMI capture, or the like? (Blackmagic Designs Web Presenter would be a perfect solution but I know implementation may not be simple)
My setup necessitates an HDMI input to the streamer and/or Portsdown 4 but I have found converters or the LKV device to be flaky at best. I could use SDI but that just adds issues.
Posted: Fri Sep 10, 2021 2:50 pm
Andy
The problem is that each new device needs configuring for each output mode.
The LKV373 will stream perfectly to the BATC Streamer if you set it to output 720p. It downconverts from 1080p very nicely. I then use this script on the RPi 4, which you will need to customise for your stream:
#! /bin/bash
LKVUDP=239.255.42.42
LKVPORT=5004
STREAM_URL=rtmp://rtmp.batc.org.uk/live
STREAM_KEY=callsign-keykey
/home/pi/hdmi/ffmpeg -thread_queue_size 2048 -fifo_size 229376 \
          -i udp://"$LKVUDP":"$LKVPORT" \
          -c:v h264_omx -b:v 1024k -r 25 \
          -codec:a aac -b:a 128k \
          -f flv $STREAM_URL/$STREAM_KEY
Just copy this text into a file called hdmi.sh in the /home/pi folder of your Portsdown, make it executable, and run it with ./hdmi.sh
This is the script that I use to stream the BATC QO-100 net every Thursday night and it has been very reliable.
Hope that helps
Posted: Sun Sep 12, 2021 12:39 am
by KA5BBC
Thank you Dave.
I will give it a go after as soon as I get a free moment, I have to repair both my analogue and digital equipment as it fell while being stored ahead of a demonstration.
Andy
Posted: Tue Sep 14, 2021 3:01 pm
by M0LIH
Good afternoon,
I am still having a few issues with my C920.
I can see it in the preview but when I go to transmit, I get a very short flash from it, but no picture.
I know the Portsdown can see it because it is there in preview and in info screen (with H264 coding from Webcam).
Please help!
Regards and 73s
Ian
M0LIH
Posted: Tue Sep 14, 2021 3:05 pm
Hi Ian
What Portsdown version (4 or 2020) and software version (2021xxxxx) are you using? All on the info screen.
Posted: Thu Sep 30, 2021 5:09 pm
by g3yjr
I've found a Logitech webcam. It says 720p on the front and a sticky label on the mount says C270.
I just tried it on Portsdown4.
M2's C920 Monitor option shows a picture.
On M1 with Source=Webcam, the green LED lights on the webcam, but the display does not move to a picture. Testcard works fine.
I'm using version 202109051.
Is a C270 supported?
73 Graham
Posted: Thu Sep 30, 2021 5:19 pm
by radiogareth
Graham, see here....https://wiki.batc.org.uk/Webcam_Support
Looks like in might, in part. Some mode/SR checking to try by the looks of things....
Posted: Thu Sep 30, 2021 5:31 pm
by g3yjr
Gareth,
yes it was the "should work with the Logitech C270" which got me excited! I'm guessing it is an older model of camera.
I've tried different combinations of Format and SR, but no joy yet.
The receiver side of the project works very well. One day I will get this project on the air!
73 Graham
