portsdown 4 with 5' display
f4fdw
Post by f4fdw » Tue Apr 13, 2021 1:18 pm
Hello
I have a problem with the latest firmware with my 5' hdmi display, the display is OK but not the touchscreen, in menu.sh, I put hdmi display, it worked with the penultimate firmware but with the last one it doesn't work anymore, someone has an idea .
73 f4fdw
Re: portsdown 4 with 5' display
Post by G8GKQ » Tue Apr 13, 2021 1:31 pm
Hi Laurent
I'm not aware of making any changes in the Portsdown code that might cause the problem. If you log in to the command line, type gui and press enter, you will then see what is detected by the Portsdown when you touch the screen.
It could be something changed in an operating system file?
f4fdw
Post by f4fdw » Tue Apr 13, 2021 2:00 pm
Hi Dave
thank you for the answer, here is the result of gui, if you can give me some info, display is hdmi 5 inch 800x480
Webcam device name is none
Video capture device name is nil
X Scale Factor = 5.118750
wscreen = 800
screenXmax = 4095
screenXmim = 0
Y Scale Factor = 8.531250
hscreen = 480
Mode Output in ReadModeInput() is LIMEMINI
In ReadBand, CurrentFreq = 437.000000, CurrentBand = 2 and band desig = d3
LimeNET Micro not detected
Entering Start_Highlights_Menu1
Value=0 EasyCap Input
Value=on Caption State
Value=auto Audio Selection
Value=NONE Attenuator Selection
Value=333 SR
Value=91 Fec
Value=d3 Band
Post by G8GKQ » Tue Apr 13, 2021 2:12 pm
That looks normal, but what happens when you touch the screen?
Have you any other ways to test the touch in other applications?
f4fdw
Post by f4fdw » Thu Apr 15, 2021 3:21 pm
is possible download old version 202102250 for test ? in this version my display work with no problem
