New Portsdown 2020 Software Update
Post by G8GKQ » Wed Feb 17, 2021 4:18 pm
I have just published a software update for the Portsdown 2020 (Raspberry Pi 3). This update (202102160) brings the System and LimeSDR software up-to-date and introduces an experimental DVB-T transmit capability using the LimeSDR Mini.
DVB-T transmit only works with the LimeSDR Mini loaded with firmware version 1.30. NOT the special DVB firmware. It is also limited to H264 encoding, not MPEG-2. The Guard interval is fixed at 1/32 and only QPSK is available. It has been tested at bandwidths between 250 and 1000 kHz. There is no DVB-T receive capability in this software (unlike Portsdown 4). Thanks to Charles G4GUO for providing this capability.
Note that (as with DVB-S/S2) there is a significant calibration power output spike that occurs a few seconds before the PTT line becomes active. However, it is more significant because the DVB-T power output is lower than that for DVB-S/S2.
The full list of updated features is:
  • New builds based on Raspios 2021-01-11
  • Update Limesuite Version to 20.10
  • Tidy LimeFPGA builds
  • Display Required TS Bitrate on Info Screen
  • Improve Jetson HDMI video quality
  • Initial LimeSDR Mini DVB-T transmit capability
As usual, you can update from Menu 3, Check for Update. The update will take a while as there are a lot of system upgrades to be applied. Just start it off and come back after a cup of tea/coffee.
Please report any bugs here.
arthur21
Re: New Portsdown 2020 Software Update
Post by arthur21 » Mon Mar 01, 2021 8:16 pm
Hi Dave
Today I had fun viewing and controlling G8XTW's spectrum analyser over the internet my dvbt signal was produced with the Portsdown 2020 and a Lime mini into a CML class A amplifier at 437MHz producing 20w O/P. I have attached a screen grab from Phil's analyser.
We then decided to take a look at the dvbs signal from the same setup with a surprising result the dvbs signal appeared at about 1.1MHz low and with an unmodulated signal at 437MHz. Has anyone else observed this or is it something strange with my gear.
LIME MINI Test report reads Hardware V1.2 Firmware V6 Gateware V 1.30 and the last 4 tests show Failed
73 Arthur G4CPE
Screenshot (102).png (180.87 KiB) Viewed 3471 times
Screenshot (101).png (177.92 KiB) Viewed 3471 times
arthur21
Post by arthur21 » Tue Mar 02, 2021 5:45 pm
Did a force update today and both dvbt and dvbs now working again.
73 Arthur
G4CPE
Post by G8GKQ » Wed Mar 03, 2021 10:22 pm
Hi Arthur
I was finally in a position to test and try to reproduce this problem today. I could not see anything amiss.
Please let me know if it happens again and we'll try to track down the cause.
The fact that the LimeSDR fails the last 4 tests is not unusual. It is normally caused by the gain of the TX and RX channels being slightly out of tolerance. You may find that it passes the tests when cold and with nothing connected to the SMAs.
g7ntg
Post by g7ntg » Tue Nov 23, 2021 1:08 pm
I have been trying to get my Portsdown 2020 to transmit DVB-T
When I try to update the portsdown software it says that I have version 202102100 loaded and that it is the latest version
When I look at lime config it says I have version 1.29 and that it is the latest version.
What am I missing? There must be something I am not doing as Alan G4HND has just done his Portsdown 2020 and I have received pictures from him.
Jim
Post by g0mjw » Tue Nov 23, 2021 1:30 pm
Mine is fine. Are you sure it isn't working? What input have you selected?
Post by G8GKQ » Tue Nov 23, 2021 2:36 pm
Hi jim
I recall that there may have been an error that prevented the update process working properly around then.
Please try "Force Update". It will take a long time, but stick with it and let me know how you get on. Once that is successful, you'll be able to update your LimeSDR.
g7ntg
Post by g7ntg » Tue Nov 23, 2021 3:02 pm
rebuilt my card from scratch and now it's working fine
Jim
g7ntg
Post by g7ntg » Tue Nov 23, 2021 3:12 pm
I tried force update but to no avail so I formatted the SD card and rebuilt it - now version 202111101
works fine now.
The card must have become corrupted
Jim
G0LJF
Post by G0LJF » Wed Nov 24, 2021 12:14 pm
Hi Dave.
Mine updated fine (but not tested yet, booted OK) but now (still) reports Version XXXXX1101 and not the XXXXX2160 version you stated.
10 minutes duration, by the way.
73, Mike
