IPTS in settings Portsdown 4
Posted: Wed Oct 07, 2020 11:50 am
by PE5PVB
Where can I find the settings, or select button to use IPTS input on Portsdown 4?
Re: IPTS in settings Portsdown 4
Posted: Wed Oct 07, 2020 1:11 pm
Hi Sjef
It's in the Encoder Menu, as it selects an external encoder and I couldn't think of anywhere else remotely logical to put it.
Note that it will not work with Pluto though, only Lime and DATV Express.
Posted: Wed Oct 07, 2020 1:27 pm
by PE5PVB
Yes, I have a LimeSDR.
Where can I find the encoder menu?
Posted: Wed Oct 07, 2020 1:41 pm
The Encoder menu is selected from the touchscreen, Menu 1, top row of small buttons, second button along.
Posted: Wed Oct 07, 2020 8:15 pm
by HB9DUG
Hello Dave,
To use the IPTS input, could you please confirm that I have to send a TS to the IP address of the PI 4 without a port number ?
Does the IPTS Monitor works on the Portsdown 4 ?
I have also read that it works only with the DATV Express board and Lime, fine with me.
73 qro de michel, hb9dug
Posted: Wed Oct 07, 2020 9:41 pm
Hello Michel
You have to send the IPTS to the IP address of the Portsdown on port 10000. The IPTS monitor works very well on the Portsdown 4 and also monitors port 10000 (only).
Posted: Tue Oct 27, 2020 6:22 pm
by Jabi
Hello all:
I confirm that run on Lime, but no in Pluto.
73,s de Jabi, ea2aru.
Posted: Tue Oct 27, 2020 7:55 pm
by PE5PVB
Well, I'm still trying. Made a mistake in the topic title, I have a Portsdown 2020 (RSP3).
Want to get my Tandberg EN8090 to work as an input for the Portsdown 2020.
When I use the IP address from the Raspberry as destination on the stream output it doesn't work. When I use 224.0.0.251:10000, I do get the picture of my streamer on the IPTS monitor, but not on the transmitter.
Stream is an UDP multicast stream.
Any ideas?
Re: IPTS in settings Portsdown 2020
Posted: Tue Oct 27, 2020 8:49 pm
The Portsdown transmitter needs a unicast (not multicast) UDP stream. The IPTS monitor uses a different method of receiving the stream - so this may work while the TX des not.
So you need to send the stream as a unicast on port 10000 to the Portsdown's IP address. It will then get picked up by these lines in the main transmitter file (rpidatv/scripts/a.sh line 1184):
PORT=10000
netcat -u -4 -l $PORT > videots &
videots is then played out into the DVB-S/S2 encoder.
Posted: Tue Oct 27, 2020 9:28 pm
by PE5PVB
OK, finally got it to work.
