sd usb reader for Portsdown builds
Posted: Sat Sep 26, 2020 8:35 am
Thanks to KA5BBC and his Moncaso 932 case with a usb card reader on the front I had the idea to try a usb sd card reader with the Portsdown software sd memory card in it plugged into the usb on the raspberry Pi.
After a few flashing lights the system started and worked as normal. This was on a Raspberry 3B+ and Portsdown 2020.
So if you want a Raspberry Pi built into a case but want to change the sd card easily then try puttng the sd card into a sd card reader instead of the sd slot on the raspberry Pi.
Will it slow the raspberry Pi down? Could this lead to multiple sd card choices? will this work with a ssd?
Over to you.....
Over to you.....
