Change Service ID (SID)
Posted: Fri Sep 25, 2020 7:40 pm
by PE5PVB
Where can I set the service ID for the program on the output?
Re: Change Service ID (SID)
Posted: Fri Sep 25, 2020 9:59 pm
The Program ID can be set to your callsign from one of the Buttons on Menu 3.
The Service ID is not intended to be changed and is hard-coded in avc2ts.cpp. If you do change it, you would then need to recompile avc2ts and copy its binary to the rpidatv/bin folder.
Posted: Fri Sep 25, 2020 10:01 pm
by PE5PVB
Are there plans to add this to the menu? Some repeaters do require to have a specific SID.
Posted: Sat Sep 26, 2020 2:22 pm
Hi Sjef
No-one has raised the requirement before. Please could you be more specific:
  • H264 or MPEG-2?
  • What text do you need?
  • Which repeater has the requirement?
  • Are there any special requirements for PIDs?
  • What output device? Lime, DATV Express or Portsdown F-M board (Not possible for Pluto)
  • Which Portsdown version? Portsdown 4 or Portsdown 2020
I can then scope whether a software change is practical.
Posted: Sat Sep 26, 2020 2:42 pm
by PE5PVB
It’s not a text but just the SID, which is a value.
Posted: Sat Sep 26, 2020 3:19 pm
I'm still not clear what parameter within the TS you need to be set. Please could you define it in exact terms according to this document (page 44 or near) https://ecee.colorado.edu/~ecen5653/ece ... 3818-1.pdf
I also need all the other questions answered.
Posted: Wed Oct 07, 2020 11:45 am
by PE5PVB
Sorry for the late response. Usually in a MSPT stream (Like on a BSkyB transponder on a satellite) you have multiple TV stations. Every station has it's own SID (service-ID or program-ID). Your settopbox will use this SID to get the right audio-PID, video-PID, PCR-Pid etc from the SDT table.
Even with only one service, this info should be available. Many Dutch ATV repeaters with DVB inputs are looking for the SID or APID/VPID. Like PI6ATV.
https://www.pi6atv.com/techniek/
