C525
Posted: Sun Jun 23, 2019 9:50 am
by f4fdw
Hello
The latest version of portsdown 201905090 no longer works with the webcam C525 !!! the signal on the analyzer is not stable while with the test pattern it is OK, with the previous version it worked, can we go back? or is there a solution? .
thanks
73 F4FDW Laurent
Re: C525
Posted: Sun Jun 23, 2019 5:50 pm
Hi Laurent
Are you using the Portsdown filter-modulator or the LimeSDR?
H264 or MPEG-2?
What SR?
What was your previous version number?
I am unable to test with a C525 as I don't have one - so this is difficult!
Re: C525
Posted: Sun Jun 23, 2019 9:03 pm
by f4fdw
Hi Dave
Version 201903xx is ok , I have tested with lime mini with all SR 125-1000 and h264
73. F4fdw
Re: C525
Posted: Sun Jun 23, 2019 9:21 pm
Hi Laurent
I changed to a new version of Evariste's avc2ts software around then, and that may have caused the problem. I'm sorry, but I can't even try to fix it without a C525 to test with. If the problem is with Evariste's software, I will not be able to fix it at all.
The C920 WebCam is the only one that I try to maintain full support for - all others are on a best-efforts basis, as I do not have the capability or the time to test them.
Sorry
Re: C525
Posted: Mon Jun 24, 2019 10:50 am
by f4fdw
OK Dave
I will go back to the old version
73 Laurent f4fdw
