Eric / Nick
345mmx258mmx145mm ABS Plastic Electronic Project Junction Box Enclosure Case as a search item on Ebay gives a £40.36 product in stock from Hong Kong.
I do wish a club expert would reply to my topic on 7" screen and any chance of composite video out - please.
My new Lime Portsdown under construction has a Waveshare A 3.5" screen (regretably) in order to work with FM transmitters via Comp video out. But it'll be small like M0XTD's CAT18 construction competition winner example.
[Off topic :- I pray for a single computer DATV transceiver so my small Portsdown and a Minitiouner could work together from rucsack portable SOTA summits. What does SDRAngel do on Linux? It was doing demod of DVB-S and had the word Viterbi on the display on the YouTube from SignalsEverywhere stream ]
Happy building
David M0YDH
Case for Portsdown using 7 inch screen.
Re: Case for Portsdown using 7 inch screen.
Hi David
What is required to enable composite video output with the 7 inch screen is a Raspberry Pi hardware/device driver expert, not a club expert!
The current situation is as stated on the Wiki: https://wiki.batc.org.uk/Portsdown_Disp ... ouchscreen. I've run out of ideas....
