Hi all,
I resumed my test and unfortunately no positive results. In fact, in reading the various Portsdown scripts it is clear that in IPTSIN mode the adress taken into consideration is the RPI TCP on the Network. (Menu.sh line 319) The port is fixed in a.sh line 1105 Port=10000. This systeme is fully functionning with Vmix as it is the TCP adress which is retained and the port is also confirmed in the various .bat files used in relation with Portsdown and to date is OK for this use but except that Minitioune is using UDP adress and not TCP. I tried to modify line 1106 (a.sh) as netcat command refer to UDP (-u) and I add the Minitioune UDP adress and Port in the sentence. But nothing....
As we say in French, "j'en perd mon Latin" I confirm that Minitioune flux is correct either with VLC or TSreader. I also open the corresponding Ports in Kaspersky Firewall to avoid any port blocking. In checking with a Network analyser, with VLC/TSreader the correct Port/adress are active but nthing with RPI/Portsdown.
I assume that other OM would be interested to use Minitioune as source with Portsdown to make a simple repeater. To do, I think it will be usefull to have a additional item in menu allowing the use of Minitioune as source. Of course, it will be judicious to have menu which permit the choice for adress and port as it is possible in Minitioune.ini. Unfortunately I'm not enough expert in Linux to help in a satisfactory way but remain confident with BATC fellows.
Thanks your help.
73's Bernard F1NST
