Non Stock Frequencies
G4uvz
Post by G4uvz » Tue May 01, 2018 5:17 pm
I am pretty sure that this is possible ...but how to do it ?
If when using my 10GHz transverter I want to move out of the beacon band ,,,I need to transmit on 148Mhz for example?
Adrian
Re: Non Stock Frequencies
Post by g8gtz » Tue May 01, 2018 5:32 pm
Normal Portsdown support is currently unavailable, so I will attempt an answer as I asked the same question last week!
You cannot enter a random frequency (at the moment?) but if you go to "Menu 3" > "set preset freqs" you can edit the preset frequencies. These can then be recalled when you press "Freq" on the main menu.
G4uvz
Post by G4uvz » Tue May 01, 2018 5:53 pm
Thanks Noel..I will give it a go!
A
