TX button on screen display
Posted: Sun Feb 11, 2018 4:37 pm
by F1SSF
Hi alls,
Very often, when I press TX button to stop tranmission, TX stop, and restart immediatly.
Impossible to stop TX, I must going in generator menu , and TX stop.
What do you think about this ?
Best 73 Franck F1SSF
Re: TX button on screen display
Posted: Sun Feb 11, 2018 8:40 pm
Franck
What screen are you using? Do you use a pointing stick or your finger? What vision source is this with? Camera, or testcard or what?
Posted: Sun Feb 11, 2018 9:04 pm
by F1SSF
Thk's , I use the last update version, no stick, my finger only .
For my source, I use TS file on USB key.
My screen is correctly calibrate, problem only with TX touch.
When I press TX to STOP, the PTT led turn OFF, but when I released my figer on TX button, PTT return to ON, and RX button is again red.
it's unpleasant hi....if you have an idea.
All the best, 73
Franck
Posted: Tue Feb 13, 2018 9:11 am
Franck
Is the problem only in FileTS mode, or does it happen in other modes as well?
Posted: Tue Feb 13, 2018 11:53 am
by F1SSF
Dave,
I 've found an intermediary solution, I press others buttons, and TX stop..
Not important at this time......it's more more easy now, it is peharps a good method
I continue my portsdown tests.
Many thank's
Franck
Posted: Tue Feb 13, 2018 4:46 pm
Hi Franck
I’ve found the bug. It will be corrected in the next update - hopefully later this week.
Posted: Tue Feb 13, 2018 6:15 pm
by F1SSF
Super Dave, not urgent. Tk's
73's
Posted: Wed Feb 14, 2018 12:29 pm
I've just released the software update that includes the fix. Thanks for reporting the bug - I can only fix problems that I know about!
