Touchscreen Issues
Posted: Sun Jan 21, 2018 11:55 pm
I have just enabled the touchscreen mode to check it out before connecting the Filter/Modulator and other boards and have an issue or two. Only the Pi is powered up.
When toggling between various options the screen freezes occasionally and the only option is to power down and restart. At first I thought it may be due to my mounting of the screen - maybe some of the touch sensitive area was in contact with the front panel.
To check this I removed the screen from the panel but the problem still occurs.
Another problem was when I select transmit the TX button turns RED and as I had Pattern selected the various testcards run, but I am unable to get out of transmit back to the menu screen. I believe you touch the screen anywhere to stop TX mode.
I used Putty to try and see what is happening and noticed what appears to be common between the two faults.
In both cases the following messages are displayed when the problem occurs:-
Button Event 21
Status 0
DISPLAY OFF
Entering LeandProcess
Entering FFT Thread
I have no idea what they mean but this seems to be the point the screen stops working.
I have attached screen shots of the Putty screen showing the issue.
I am using an old version of software, not the latest release.
Any help in curing this issue would be appreciated.
Regards,
Nick - G4NKV
Button Event 21
Status 0
DISPLAY OFF
Entering FFT Thread
Regards,
Nick - G4NKV
