Portsdown Enhancement - Transverter Switching
G4uvz
Re: Portsdown Enhancement - Transverter Switching
Post by G4uvz » Thu Jan 18, 2018 3:58 pm
Dave...if I implement the hardware solution ...will there still be the ability using the new attenuator module, to have a different drive level on the ..70 Mhz / 2M transverter port?
MN-tech
Post by MN-tech » Thu Jan 18, 2018 4:43 pm
Here is a bit of logic to eliminate accidental 70cm/23cm selection by the transverter switch. Other Nand gates could be used.
The resistor can be anything in the neighborhood of 10K.
A software method of using the 4M port for the transverter could be done with one additional output from the Pi for the RF output switch LSB.
4M tranverter output.PNG (7.26 KiB) Viewed 2249 times
Post by G8GKQ » Thu Jan 18, 2018 11:28 pm
Hi Adrian
Yes, with a slight rewriting of John’s logic, it should work with the attenuator logic as I currently envisage it.
G4uvz
Post by G4uvz » Fri Jan 19, 2018 8:44 am
Thanks Dave for all your efforts in programming ..trying to keep us all happy!
A
