Lenkeng HDMI over IP extender – LKV373A
F5SWB Dimitri
Post by F5SWB Dimitri » Wed Jan 03, 2018 12:36 pm
Hi everybody,
I recently bought a Lenkeng HDMI over IP extender – LKV373A transceiver and receiver.
https://www.amazon.fr/gp/product/B00TO8 ... UTF8&psc=1
All is ok on my network in live tv but i would like to use it to send ip video to the Porstdown Digital Transmitter ...
it's possible to get the video in my network with vlc via rtp://@239.255.42.42:5004.
If someone could help me to succeed ... any help will be very appreciated :)
if this can help : https://blog.danman.eu/new-version-of-l ... #more-468
73's Dimitri.
Re: Lenkeng HDMI over IP extender – LKV373A
Post by g0mjw » Wed Jan 03, 2018 5:01 pm
The performance of these devices is remarkably good for their cost. To send to the Portsdown you need to use UDP to the PI address. It might be able to (probably can) handle rtp but I expect that will need some programming. Do that yourself or ask Dave and duck.
I also had to change my firmware, there is info on the net about that, here I think https://blog.danman.eu/new-version-of-l ... r-lkv373a/
The only problem I have found with that unit is that the bit rate is not as constant as the PI may want for sending over the air. It had no problems sending HDMI io VLC on the PC.
F5SWB Dimitri
Post by F5SWB Dimitri » Thu Jan 04, 2018 1:35 pm
Hello mike and many thanks four your answer,
I've got the last version of fimware
TX SERVER : Version : 4.0.0.0.20161116 Encoder Version : 7.1.2.0.11.20161116
The resolution actually is a little bit strange :
Codec + h264 - mpeg4 avc
Resolution : 1728x1090
Resolution screen : 1728x1080
actually I can't access to any webserver to change the settings.
If I downgrade to an old firmware are you sure it will be possible ?
If it doesn't work I couldn't be back to the last version, working good with the receiver.
To be continued or not ...
73's dimitri.
