Off set test card?
Discussion about this major DATV Project. See also https://wiki.batc.tv/The_Portsdown_Transmitter
G4uvz
Contact:
Off set test card?
Post by G4uvz » Tue Dec 12, 2017 4:05 pm
For some reason one of the cycle of test cards seems to have moved sideways...it's the same on the rpi screen and the off air signal?
Adrian
Re: Off set test card?
Post by G8GKQ » Tue Dec 12, 2017 4:17 pm
Hi Adrian
Well spotted! Yes, I erroneously saved the test cards that I am using for the CardMPEG2 mode in the folder for the carousel of cards. They are a larger image size (720x576 vs 640x480) so overflow the top and right of the screen.
I'll correct the problem with the next software update.
PS - There is one advantage. If you've ever used the CardMPEG2 mode with the caption enabled, you'll find that one of the cards has your callsign on it.
G4uvz
Contact:
Post by G4uvz » Tue Dec 12, 2017 4:31 pm
Thanks Dave! Ken BVK can just about rx me on 437 SR1000 ..which is on H264..he asked if I could send on MPeg2 ..but not sure how to do this ...if indeed I can!
Adrian
Post by G8GKQ » Tue Dec 12, 2017 6:58 pm
