U41 hot
Posted: Wed Nov 01, 2017 2:09 pm
I'm testing the filter mod board that I built with the LO and Pi as per the instructions here: https://wiki.batc.tv/Filter_Modulator_b ... _the_board
Pictures are being picked up on the MiniTiouner and I've done a quick check on 2m, 70cm and 23cm outputs - all OK.
The filter mod power regulator is cool, as are all the ICs apart from U41. This is running quite hot - I can put my little finger on it for a couple of seconds before it gets painful.
Is this the usual temperature or could I have a fault with my assembly? I did try to run solder through the vias below the exposed pad as per Colin G4KLB's video, but maybe I didn't do enough.
Thanks and 73
Ray M0DHP
Thanks and 73
Ray M0DHP
