Page 1 of 2
PAs for Portsdown
Posted: Thu Oct 19, 2017 11:30 am
by G3JZF
Guys I have a GH Engineering PA unit PA1 3G18 which is a FM PA block with a Motorola M68719.
Is it of any use as a PA for the Portsdown TX?
I also have a Microwave Modules MML 432/100 which is a Linear Amp for 70cm. Can anyone suggest a suitable amplifier that would drive it?
Any help would be much appreciated.
John G3JZF Sutton Coldfield
Re: PAs for Portsdown
Posted: Thu Oct 19, 2017 6:02 pm
I doubt it is linear enough for DATV. Best check with other users as it might be. However if not with a few modifications you may be able to replace the RF module for one from the RA series.
Please don't use the MML amplifier on 70cm on DATV. All the ones I have tested have not been linear enough and have unacceptable spectral regrowth (Shoulders) for use on 70cm. The biasing circuit was not designed for it. You might be able to modify it by increasing the bias current but its unknown if that would work. If it does you won't get any more than 10W out so the Portsdown might be sufficient to drive it directly.
Mini-kits do a nice RA module based amplifier that would give you 5-10W. Higher power is currently difficult. This is because DATV requires very linear amplifiers. On 2m I get 5W out of a 70W device, running it at 3A bias current.
Needless to say, anyone using DATV probably needs a spectrum analysis to check their transmissions. Fortunately, an RTL Dongle will do fine for this. Maybe a TX spectrum plot is another one for Dave's Portsdown ToDo pile.
Posted: Sun Oct 22, 2017 12:20 pm
by G3JZF
Many thanks for your reply - all comments noted.
I dug out a RA07H4047 that I had had by me for some time. I set it up according to the data sheet and it worked first timer. With a 10dB attenuator after the Portsdown and a dummy load on the output it appears to be working well with a perfect testcard on my Minitiouner. I now need to get my RTL dongle working, build a better attenuator system and sort out power supplies and filters. Hopefully, I am now on my way.
I do thank you for your interest and will shout out if I need more help.
vy 73
John
Posted: Wed Oct 25, 2017 3:09 pm
by g3zgz
I'm also looking at using the Mitsubishi modules for 2m and 70cm
Would you recommend I go for the 30watt or 60watt versions of the modules, and why?
G3ZGZ
Posted: Fri Nov 10, 2017 3:59 pm
by radiogareth
Would one of these be good/great for DATV? http://g4fev.atspace.com/dolphinpa.htm
Bought one a while back to add to the 'play-pile'. Untouched at the moment....
Posted: Fri Nov 10, 2017 4:21 pm
radiogareth wrote:Would one of these be good/great for DATV? http://g4fev.atspace.com/dolphinpa.htm
Yes - I would think so, but don't do the bias changes as you will need it as linear as possible.
Posted: Fri Nov 10, 2017 4:25 pm
by radiogareth
Yes, I'd leave that part 'as-is' as far as I can recall it was designed to be ultra-linear anyway. What a wise buy :-)
Posted: Fri Nov 10, 2017 6:13 pm
I use a Nokia dolphin PA on 70cms. No bias modifications and it will give a clean 30W of DVB-S.
Posted: Fri Nov 10, 2017 7:04 pm
by radiogareth
Thats very good news. And me quiet for several days ;-)
What are you driving it with?
Posted: Sat Nov 11, 2017 8:25 am
I use an MHW710 amplifier and feed about 1 watt into the Dolphin's driver stage.
