Audio and Video Capture Devices - Help Please!
Post by G8GKQ » Sun Jul 02, 2017 8:36 am
I am doing some development work to automate the switching of audio and video capture devices on the Porstdown, and want to make sure that it is likely to work with everybody's devices. For this I need to know what you are using.
To get the information, please plug in your microphone dongle AND Video capture dongle, and go to the command line (from the Console Menu, Shutdown and Reboot Options, Option 3, Exit to Linux). Then type in (or copy and paste) the following command:
arecord -l
(thats a lower case l as in lima).
Please paste (or photograph or screenshot) the response here. It should be something like:
**** List of CAPTURE Hardware Devices ****
card 0: usbtv [usbtv], device 0: USBTV Audio [USBTV Audio Input]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 2: Device [USB Audio Device], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
Once you have done this, you can type
/home/pi/rpidatv/scripts/menu.sh menu
to get back to the console.
If you help me with this, I can make sure that I support your configuration. If you don't bother, please don't complain when the next update breaks your Portsdown!
i2NDT
Re: Audio and Video Capture Devices - Help Please!
Post by i2NDT » Sun Jul 02, 2017 8:59 am
mine is exactly the same:
Subdevices: 1/1
I am using the BATC dongle.
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
Post by g0mjw » Sun Jul 02, 2017 9:12 am
Here you go:
pi@raspberrypi:~ $ arecord -l
card 1: U0x534d0x21 [USB Device 0x534d:0x21], device 0: USB Audio [USB Audio]
Subdevices: 1/1
f1faq
Post by f1faq » Sun Jul 02, 2017 1:29 pm
Here are mine
card 0: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevices: 1/1
Card 0 does not show any info. It is a low cost chinese "3D sound" dongle
Typing lsusb gives more : Bus 001 Device 013: ID 1b3f:2008 Generalplus Technology Inc.
Card 1 is an EasyCAP
73's - Christian
73 - Christian
F1FAQ
G4KLB
Post by G4KLB » Sun Jul 02, 2017 9:58 pm
card 2: STK1160 [STK1160], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 3: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
also use
Subdevices: 1/1
card 1: U0xeb1a0x2861 [USB Device 0xeb1a:0x2861], device 0: USB Audio [USB Audio ]
Subdevices: 1/1
Colin G4KLB
Post by G8GKQ » Sun Jul 02, 2017 10:16 pm
Thanks Colin
I had all the others so far, but had forgotten the STK1160.
Any more out there??
g3xig
Post by g3xig » Mon Jul 03, 2017 2:34 pm
My Pi identifies a simple headphone / microphone dongle and EasyCap adapter as follows:
card 1: Set [C-Media USB Headphone Set], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 2: usbtv [usbtv], device 0: USBTV Audio [USBTV Audio Input]
Subdevices: 1/1
Regards,
Clive
Post by g0mjw » Mon Jul 03, 2017 7:22 pm
Here is a USB audio dongle
card 1: AUDIO [USB AUDIO], device 0: USB Audio [USB Audio]
Subdevices: 1/1
KenW6HHC
Post by KenW6HHC » Tue Jul 04, 2017 3:17 am
Hi Dave G8GKQ,
I am running my RPi3/Portsdown-SW/DATV-Express-modulator in the CAMPEG-2 mode with the PI-camera installed and a Logitech USB-based headset with boom-microphone also installed. The audio seems very reasonable. My linux printout is:
card 0: Headset [Logitech USB Headset], device 0: USB Audio [USB Audio]
Subdevices: 1/1
73...de Ken W6HHC
borzwatson
Post by borzwatson » Tue Jul 04, 2017 10:12 am
card 0: USB20 [AV TO USB2.0], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Thanks for all your work on this.
73 Simon M0ZSU
