Pi camera levels
Posted: Tue May 09, 2017 3:35 am
I notice when using the connect Pi camera on my Portsdown the levels are ok for inside use but if I point the camera out the window the levels are way too high and washed out, is there any settings that can be altered or ALC set? had a look but didn't see any from the menus
Currently I'm running the basic Portsdown modulator board and playing with the various settings and making the system a bit portable to allow some outdoor testing to be done, My Pi camera is running via and extension HDMI cable and pertit studios adapters at each end. Everything is working fine so far great project.
cheers Rob ZL3TCM
cheers Rob ZL3TCM
