Portsdown Freezes
Posted: Thu Mar 30, 2017 7:28 pm
I have just updated to 20170306 software and according to screen information went successfully with no errors.
After setting up the various parameters in CLI mode, rebooting and it starts in Touchscreen mode no problem. If I then select transmit in Ugly mode it works well for about 30minutes then freezes. For example, if test pattern is running, the scrolling feature stops and I cannot revert to normal screen.
When I reboot and go into CLI mode again, everything is OK except the Display setting for Waveshare screen in my case has reverted to first option Tontec35. This is entirely repeatable and is the only parameter that changes from my other settings.
Running on PI3 with official 2.5A psu, have tried another PI3 with same result. I should also say if the PI3 is booted and left alone, it still freezes after about 30 min and without touching anything. I wonder if it is a heat problem, so will try some heat sinks on the ICs in the PI.
Cheers
Andy
Cheers
Andy
