Transmitter Software Capabilities and Issues (Jessie)
KenW6HHC
Re: Transmitter Software Capabilities and Issues
Post by KenW6HHC » Fri Jun 09, 2017 6:57 pm
Hi Dave G8GKQ,
OK...good to know that it already on your "track down list".
I can certainly live with the quirk...now that I understand it. I just need to use PTT first to bring-up-the repeater....and from that point on, ViewFinder video will work OK.
I was a bit concerned that this may only occur when using the DATV-Express board as the modulator. But, you made it sound like that this also occurs with Portsdown modulator board.
Thanks for the info and all your efforts.......de Ken W6HHC
KenW6HHC
Re: Transmitter Software Capabilities and Issues - video latency
Post by KenW6HHC » Mon Jun 12, 2017 2:46 pm
Hi Dave G8GKQ,
I noticed a very repeatable jump in video latency occurs while in the CAMPEG-2 camera mode and using the DATV-Express board as the modulator. My tests were all performed with FEC=1/2 and SR=1000 and SR=2000 with the same results.
Transmission
Duration............ Video latency
1) <55 minutes.......1.5 seconds (very acceptable)
2) >65 minutes......12.5 seconds
The Video latency returns to 1.5 seconds if I stop the transmission, pause, and then start to transmit again.
This probably is a very low priority issue since most DATV QSO transmissions do not last 60 minutes...only perhaps videos clips and slide-shows, and the jump in latency would be difficult to notice after it occurred.
...de Ken W6HHC
G8XZD-TV
Post by G8XZD-TV » Mon Jun 12, 2017 6:34 pm
KenW6HHC wrote: This probably is a very low priority issue since most DATV transmissions do not last 60 minutes...
...de Ken W6HHC
You've never watched a G4KLB over then :-)
Post by G8GKQ » Tue Jun 13, 2017 3:41 pm
Ken
Thanks for the info. That's a bit worrying as one of our future applications for the Portsdown is repeater streaming, 24/7. I'd be interested to know what happens at the 2 hour point - it might help track down the cause.
KenW6HHC
Post by KenW6HHC » Thu Jun 15, 2017 8:25 pm
I will run a two hour test today to see if the addition video latency continues or increases, etc.
73...de Ken W6HHC
KenW6HHC
Post by KenW6HHC » Fri Jun 16, 2017 4:51 pm
Hi Dave G8GKQ,
There were no further video latency changes after 1 hour. I ran tests to just over four hours.
As a reminder to readers...the jump in video latency occurs while in the CAMPEG-2 camera mode and using the DATV-Express board as the modulator. My tests were all performed with FEC=1/2 and SR=1000 and SR=2000 with the same results.
Transmission
Duration................... Video latency
1) <55 minutes................1.5 seconds (very acceptable)
2) >65-to-115 minutes......12.5 seconds
3) >125-to-235 minutes.....12.5 seconds
4) >245 minutes..............12.5 seconds
I can NOT test to see if this video latency quirk also occurs with a Portsdown modulator board in a set-up? My first suspicion is RPi-3 code (maybe kernel...maybe FFMPEG encoding not behaving correctly)?? BTW...the VIEWFINDER video displayed on LCD never is impacted....the touchscreen latency always stays around 1.5 second.
...de Ken W6HHC
Post by G8GKQ » Fri Jun 16, 2017 7:37 pm
Hi Ken
Thanks very much for doing these tests - they help a lot. I'll take a look at the problem as soon as I can.
i2NDT
Post by i2NDT » Sat Jun 24, 2017 2:46 pm
Hi Dave!
I have my RPI+SD card (by BATC) and Waveshare screen (nothing else) all connected together. everything is ok as I can transmit (ugly mode and paternaudio) and I see the carrier on my SA.
I am able to go back to stand by mode touching the hidden TX button and than I can change all parameters. so all "buttons" work except the RX one! when I touch it the screen freezes...and I have to reboot to be able to control the touch screen again.
I have also updated to the latest software release but no improvement. than, tampering with my SSH terminal (pibootstrap) by mistake I also updated raspian jessie...but again no improvement!
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
Post by g0mjw » Sat Jun 24, 2017 2:57 pm
I think I have seen this too - however, unless you have a receiver plugged in there isn't a lot of point in the RX button. Might make sense to disable it's function if no receiver is detected.
i2NDT
Post by i2NDT » Sat Jun 24, 2017 4:02 pm
actually if I plug in a RTL dongle the RX button works! the RX screen shows something similar to the constellation pattern...but I do not understand it's purpose!
i2NDT Claudio
Dalmine, Italia
