Portsdown 2018 Stretch Software News
Re: Portsdown 2018 Stretch Software News
Hi Dave
A very minor thing I found. Changing the lime gain is not saved as default. If I change it to 70 say, it always goes back to 90 on next boot. Saved ok with presets.
Many thanks
John
Many thanks
John
John
Thanks for reporting this. I have found and corrected the error with Lime Gain. The fix should be in the next release.
New Portsdown Stretch Software Release 201810270
This major new software release includes the following features:
PLEASE NOTE THAT THIS UPDATE TAKES AT LEAST 25 MINUTES TO COMPLETE, AND CAN TAKE UP TO 2 HOURS. Slower SD Cards take longer to compile the new audio software. Please contact me if you have a problem - if the update runs longer than 3 hours or freezes, do not try a second update.
- Initial implementation of H264 encoding with audio
- Nightly streamer reboot
- Reduce "popping" on streamer audio
- Improve C920 selection logic
- Correctly load Lime Gain after boot
Just done the update on my (non +) system, it took just over 20 mins and looks ok. Thanks to you and Evariste for amazing work.
73 Dave M5TXJ
73 Dave M5TXJ
Just upgraded to Stretch 201811030 and my animated testcard lacks any animation? It's always worked before. Running on a RPI3B+ on a 16Gb Sansdisk.
Output to ugly, H264 DVB-S.
Have I upset it?
Have I upset it?
Hi Gareth,
I updated my system over the weekend and found many of the settings had become corrupted, what is more the changes i made to put them right woouldn't stay put.
Normal operation was restored by the restore defaults option.
Kind regards, David.
Hi Gareth
If you check the transmitted signal, you will find that the animated test card is working and much smoother than before. It is just not displayed on the touchscreen. Documented here: https://wiki.batc.org.uk/H264_Encoding_ ... im.29_Mode
Thanks David and Dave for pointing out what I read the other day -sorry!! It spent a lot of time doing the Lime SDR compile and install this time, if it makes my Lime work, great, just how much can a RPi be made to do? Inspirational
Hi Dave
Did update earlier in 20 minutes, no problems found so far, very many thanks for a super system and of course to Evariste as well!
Andy G3UEQ
Andy G3UEQ
Can we use LimeSDR mini in RX?
Thank you.
Stephane.
Thank you.
Stephane.
