portsdown 4
Pa3fbx
Re: portsdown 4
Post by Pa3fbx » Mon Oct 07, 2024 10:26 am
joefran7300 wrote:
Sat Oct 05, 2024 11:00 am
Hi Mike
Thank you for the information i will try that but mu Puto is connected to the Portsdown 4...
73'Joe 9H1GT
You have 2 options when the Pluto is connected to the USB of the raspberry.
Option 1 is use OBS to stream to the IPTS in Portsdown,
or
Option 2 use the raspberry to portforward the network to the usb.
I have made my raspberry multiboot on 1 32Gb sdcard.
This means i can select the working of the raspberry to do a portsdown or port forwarding.
This creates the pluto to be used stand alone or via windows pc for narrowband (sdr-console) or datveasy for datv.
Benno
joefran7300
Re: portsdown 4
Post by joefran7300 » Sat Oct 12, 2024 12:53 pm
Hi Benno
Thank you for the information,yes i have the Portsdown connected to the Pluto so i can use the first opition and i have the IPTS MONITOR on the Portsdown but i do not known how to configer the PC to see the Portsdown..
73,s
J
joefran7300
Re: portsdown 4
Post by joefran7300 » Sat Apr 19, 2025 10:58 am
Hi Mike
It has been long time since we talked about the portsdown for streaming from OBS ..now i has connected with each other but i have a problem with high delay from switch on to TX and also to switch off TX and even when i change to pictures in OBS on the portsdown it take too long to gange and on air the transmitting picture is not continuance..
Do you have any ideas please..
Many thanks
Best regards
73's Joe 9H1GT
