Portsdown Stretch 2019 Software Update 201903250
Re: Portsdown Stretch 2019 Software Update 201903250
Post by radiogareth » Thu May 02, 2019 6:47 am
Yes that's fixed it thanks, nicely placed :-)
F5CAU
Post by F5CAU » Thu May 02, 2019 9:32 am
Once the configuration is done, and assuming you dont want to change any parameter, you dont need a LCD screen nor Putty, is there a way to switch to transmit via a gpio pin ?
thank you, 73 de Gil F5CAU
Post by g8gtz » Thu May 02, 2019 9:51 am
Hi Gill,
Yes - as always the answer is on the wiki :-) https://wiki.batc.org.uk/Hardware-only_ ... _Switching
g7ntg
Post by g7ntg » Wed Jun 05, 2019 12:41 pm
Hi Dave
I am running the latest update with Lime Mini but am unable to transmit 16:9 picture what do you think I have done wrong?
Jim
G7JTT
Post by G7JTT » Wed Jun 05, 2019 1:16 pm
Hi Jim there is an issue with MT (well LAVfilters) that miss reports 16:9 if your using H265 ? With H264 it should be ok I TX in 16:9 in H264 and It works ok.
All best John
Post by G8GKQ » Thu Jun 06, 2019 12:16 pm
Jim
Please give me further details of what settings don't work for you - are you getting any picture? A photo of Menu 1 in the non-working configuration is probably best.
I have found a bug in the Jetson code with the 16:9 setting, but not sure that you are running the Jetson.
g4bvk
Post by g4bvk » Thu Jun 06, 2019 7:57 pm
I think I maybe having the same problem as Jim. I’m trying to set the format when using S2 QPSK, H.264 to 16:9, but the software won’t let me. If I go into format, you can select 16:9, but when you go back it’s still set to 4:3. When using M-PEG2 it seems to work fine.
Ken G4BVK
