1k Series restors on ADF4351 and PE43703
heatherlomond
Post by heatherlomond » Thu Nov 20, 2025 12:24 am
I want to have an ADF4351 and an attenuator in my Portsdown 4.
I am unsure about the 1k resistors. I think it comes down to a choice between these 2 options?
              |-- 1k -- ADF4351 CLK
Pin 29: CLK --|
              |-- 1k -- PE43703 CLK
or
                    |-- ADF4351 CLK
Pin 29: CLK -- 1k --|
                    |-- PE43703 CLK
And presumably the same for Data on pin 31?
Also I assume I need a 1k in the line from to pin 33 to ADF4351 LE and another for pin 10 to the PE43703 LE so:
Pin 33: LE -- 1k -- ADF4351 LE
Pin 10: LE -- 1k -- PE43703 LE
Can someone confirm which option to use for CLK and DATA and if I have the LE 1ks correct?
Heather
Re: 1k Series restors on ADF4351 and PE43703
Post by G8GKQ » Thu Nov 20, 2025 9:47 am
Hi Heather
It's all about damping reflections of the sharp edges on the data/clock lines, so it's all a bit of a black art (unless you have a very high speed low capacitance 'scope).
I tend to use 220 ohm resistors at the Raspberry Pi end (only) of any data/clock/switching line. If you are running 2 parallel wires to the adf4351 and the PE43703 then that's 2 resistors for each line. If they are both remote in the same box, only one resistor for each line.
But don't make them too remote - 20cm seems to be a reasonable limit.
