Pico tuner help
cashy666
Re: Pico tuner help
Post by cashy666 » Mon Aug 19, 2024 12:27 am
Hi all,
now working, Dave, Brian, Keith, Gareth and Mike.....thanks for all your help...
Reinstalled the software with a different SD card
Dave, the lightning bolt only started showing since I connected the Picotuner..will investigate...
Regards
g6hfs
Re: Pico tuner help
Post by g6hfs » Mon Aug 19, 2024 9:32 am
HI Dave,
Glad it's all working for you, perhaps see you on qo-100 sometime.
g4eml
Re: Pico tuner help
Post by g4eml » Mon Aug 19, 2024 10:31 am
The Picotuner (actually the NIM in the Picotuner) does take quite a lot of current if powered from USB. Technically it is more than is recommended for a USB device and may be pulling down the power supply you are using for the Portsdown.
If this proves to be a problem then the Picotuner can always be powered externally from 12V.
cashy666
Re: Pico tuner help
Post by cashy666 » Thu Aug 22, 2024 1:31 am
Hi Colin,
thanks for the info....it did the trick..no lightning bolt!!!!
Brian, thanks for all your help....at the rate I build QO100 is a long way off....
G4HTZ
Re: Pico tuner help
Post by G4HTZ » Sat Feb 01, 2025 4:30 pm
deleted due to my error
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
Re: Pico tuner help
Post by g0mjw » Sat Feb 01, 2025 5:10 pm
D8 is just a diode and D6 is a TVS diode on the PCB, in the Schematic and in the BOM - are you reading the right files for V3?
G4HTZ
Re: Pico tuner help
Post by G4HTZ » Sat Feb 01, 2025 5:26 pm
Deleted due to my error of reading circuit
Steve G3GHZ
5665 ATV FM
