after a long time I put the Portsdown/Langstone with Pluto back into operation.
Of course updated.
Langstone works fine.
When using Portsdown, I had to set the Pluto (firmware 0303) to RTMP so that it would send. UDP didn't work.
Then it takes approx. 8 seconds until Pluto sends or until the broadcast is finished.
Is that correct? I can't remember it anymore...
Commissioning after a long time
Re: Commissioning after a long time
To use the Pluto with the Portsdown, it must have firmware v0.31-4-g9ceb-dirty loaded. No other Pluto firmware versions are supported. https://wiki.batc.org.uk/Portsdown_4_Pl ... o_Firmware
