Portsdown 4 Now Includes an RF Signal Generator
Post by G8GKQ » Wed Oct 14, 2020 1:57 pm
The latest release of Portsdown 4 adds an RF Signal Generator Facility. This works with a Pluto, DATV Express or an ADF4351, but unfortunately not with a LimeSDR.
After updating to the latest release (202010120) a Sig Gen button is added to the top line of Menu 2. Selecting this takes you to the Sig Gen Menu. Here you can select the output device to use, a settings menu, or the main control page.
From the settings menu, you can enter the IP address of your Pluto (only required if you have changed it from 192.168.2.1), check and extend the frequency range of your Pluto, and set the reference frequency for the Pluto and the ADF 4351. Changing the Pluto reference frequency here will also correct it for use with the Langstone.
If you have Pluto selected as the output mode, you will need to calibrate it near the output frequency and power that you propose to use. So select those, MAKE SURE THAT NO SENSITIVE DEVICES ARE CONNECTED TO THE PLUTO OUTPUT, and press calibrate. You can then reconnect the output and the risk of power spikes is low after that. Frequency coverage is from 50 MHz to 6 GHz and the selectable output level is from a plus a few dBm right down to about - 70 dBm (both frequency-dependent). The displayed output level is within about 1 dB on my 2 Plutos, and is corrected for the Pluto's frequency response. It is worth rebooting the Pluto (from the settings menu) before and after using it with the signal generator for accuracy and reliability.
Similarly, a DATV Express board can be used as an output device. The frequency range is 70 Mhz to 2450 MHz and the level from about +10 dBm to -30 dBm. No calibration is required and you can apply 333kS QPSK modulation to check PA linearity.
To use an ADF4351 it needs to be connected to the GPIO pins as specified here https://wiki.batc.org.uk/Portsdown_4_GPIO_Connections. It will cover from 35 MHz to 4.4 GHz, but only has 4 output levels, 3 dB spaced, around -5 dBm.
The software will also drive an Elcom Microwave source within its operating range somewhere between 10 GHz and 14 GHz (depending on the model).
Notes:
  • If you have used the Pluto to transmit SSB or DATV since switch-on, it will need rebooting for use with the Sig Gen (either just the Pluto or the complete Portsdown with Pluto) to clear out the old settings
  • The Pluto signal has a spurious 4 MHz below it at about -45 dB and 3 others (2 MHz below, 1 MHz below and 2 MHz above) at about -55 dB. Spectrum at 0 dBm 437 MHz shown below.
  • The Pluto calibration produces a pulse of up to 10 dBm.
Credits go to Alberto Ferraris IU1KVL (of Satsagen fame) for his plutotx software and to Robin Getz for his comments on that.
Please report any bugs here!
Pluto 437 0dBm.JPG (323.3 KiB) Viewed 2855 times
i2NDT
Re: Portsdown 4 Now Includes an RF Signal Generator
Post by i2NDT » Wed Oct 14, 2020 2:26 pm
Great job Dave!
do you think you can add also the "Nort Synthesized Local oscillator (SLO)"?
it will be useful to generate signals in the 10 GHz region.
but I guess it won't be possible to measure or set the output power...
best 73
de
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
Post by G8GKQ » Wed Oct 14, 2020 2:36 pm
Hi Claudio
I had thought about it, but the only NORT SLO that I have available for testing is buried in the bottom of my 24 GHz transverter box, where it works very well as the local oscillator.
I will add it to the to-do list, but it may be a few months....
i2NDT
Post by i2NDT » Wed Oct 14, 2020 2:46 pm
OK, no problems!
Claudio
i2NDT Claudio
Dalmine, Italia
