Portsdown Construction
Discussion about this major DATV Project. See also https://wiki.batc.tv/The_Portsdown_Transmitter
G4KLB
Post by G4KLB » Thu Sep 14, 2017 12:10 am
Congratulations to the worthy winners of the Portsdown construction competition at CAT 17.
If anyone took any photos of the entrants, please post them here.
Even if you didn't enter, post them here as well, we would love to have a look at them :-)
I will start the ball rolling with my effort.
G4KLB Portsdown.jpg (411.09 KiB) Viewed 761 times
Re: Portsdown Construction
Post by g0mjw » Thu Sep 14, 2017 2:28 am
Here you are
M5TXJ
Post by M5TXJ » Thu Sep 14, 2017 9:29 am
... and mine...
G4KLB
Post by G4KLB » Thu Sep 14, 2017 11:43 pm
Thanks both, keep them coming.
Some good ideas there.
G4FRE
Contact:
Post by G4FRE » Wed Dec 27, 2017 11:10 pm
A picture of the G4FRE build.
I wanted some screening, hence the metal chassis and panels in the plastic box.
I used two smps power units; one set to 5,2V for the RPI and output rf switch and one set to 8V for the DDS, Lo filter and FM. I have left space for more modules e.g. the programmable attenuator and a custom amplifier switch/controller
After having issues with supplying power to the RPI through the microusb connector I soldered power leads directly to the board. This fixed the issue
roland_F8CHK
Post by roland_F8CHK » Fri Jan 05, 2018 1:45 pm
Hi all, here is mine in a box coming from an HP 8750A:
