Which rocket lens ?
PH2M
Re: Which rocket lens ?
Post by PH2M » Fri May 03, 2019 6:50 pm
g4hiz wrote:
Fri May 03, 2019 5:24 am
Hi Frank,
Interesting. As I said previously, I have not tried the LNB as a functional unit, only the lens, which seems to work ok on a couple of dishes. The statement concerning being a 'PLL type' was based on a Single output version that I opened, please see photos below.
Jen
Hello Jen,
Yes I did see You bought the Single output version, I took the gamble buying the Twin version (was even doubting about the Quad version), but sadly the Twin version = DRO :evil:
I have decided to stay with my present Inverto (Single)Longneck before going to any Twin or Quad (I finally want to use at least 2 ports for simultaneous NB + WB QO-100 RX
73 de Frank PH2M
G8PEF
Post by G8PEF » Sat May 04, 2019 6:44 am
G4FRE wrote:
Wed May 01, 2019 8:27 am
thats the way that also worked for me
g4fre
Yay! Success.... I now have a 'lovely' red lens which came off intact.
Incidentally, the reason it wasn't gunked onto the w/g with silicone is that it has a nice o-ring seal trapped between the face of the w/g and a small lip on the inside of the lens.
I'm curious about the internal construction of the lens, and I can get hold of another one of these lnbs, so I might sacrifice a lens - saw it in half, nose to tail - to see its insides.
Now looking for materials for the feed - any thoughts on whether copper or brass is better for the sheet/tube ?
g4hiz
Post by g4hiz » Sat May 04, 2019 7:21 am
Hi Frank,
Sorry to hear that you didn't get what you were expecting with your Dual o/p AB LNB. One thing that crossed my mind was whether it was from 'old stock'. Looking at the serial number of your unit, it starts with 2016... whereas my Single unit starts with 2017....I took a look at the AB website and all models appear to have the same Phase Noise spec and imply PLL type.
Not wishing to get drawn into LNB discussions on the 'Lens thread' but I looked at a Single o/p device that I have. It looks pretty straightforward, with no apparent filtering and so I checked the RF output on the spectrum analyzer. The noise shape seemed pretty flat from about 600MHz upwards until about 1.4GHz (where it dipped a bit), this with the 9750MHz LO. Using test signals in a rough radiated environment, 10494MHz (744MHz at IF) was in the 'flat' part of the spectrum, similarly with 10368MHz (618MHz at IF). This was of course, a PLL type as pictured previously. If I get time, I shall check its performance on QO-100.
Good luck with your dual output system !
Jen
G8PEF
Post by G8PEF » Wed May 15, 2019 9:58 am
g0mjw wrote:
Tue Apr 30, 2019 5:41 am
That's the one you want, with the flat end and in two pieces that slot together. The pointy thing it for cases where you cannot get a rocket lens, and there is a newer design by HB9PZK of that which is better that will be published soon.
Ok, now I’m confused. Both Mike and Noel (who has seen the actual lens I have) have both have said that what I have is ‘the one I need’...
However, on re-reading Mike’s post (above), it mentions “two pieces that slot together” - mine is a ‘single’ piece (well, ok it’s a red outer shell with white insides, but they seem to be bonded together).
I’ll try to attach a couple of pics of one slightly damaged one so you can see what I mean.
The other thing is that it doesn’t fit on the end of 22mm pipe - the internal diameter of the red bit is too big. It is, however a reasonably good fit into 28mm copper pipe.
All comments and suggestions welcome.
John M
Rear view
Rear view
Front view
Front view
G8PEF
Post by G8PEF » Wed May 15, 2019 10:05 am
Ah! I have just managed to get the white bit out of the red shell. The inner appears to be just a cylindrical white block (polyethylene?) apart from the single machined/moulded ring on the end facing the waveguide, visible in the photos above.
Comments welcomed.
J
Post by g0mjw » Wed May 15, 2019 10:10 am
Never seen one of those - but its still a lens so stick it on the end of the waveguide as best you can and see if it works.
g7ntg
Post by g7ntg » Mon May 20, 2019 8:31 am
I tried various lenses and horns with my POTY patch antenna on a 1.2 metre dish with a f/d of 0.4 but everything I tried caused either a drop in received signal strength or transmit power. I ended up with the waveguide projecting 7mm in front of the patch (1/4 wave at 10.4 GHz) which seems to give the best results for transmit and receive.
I used a rocket lens on my 80cm sky dish which gave a few dB improvement on receive on narrowband.
PA3FYM
Post by PA3FYM » Mon May 20, 2019 6:22 pm
Some experiments with several lenses were performed here.
Using a 10 GHz beacon and measuring the received sig strength with
a HP-435 (m)Wattmeter it was possible to reach 0.1 dB accuracy
and also determine the -10 dB opening angle(s).
More information to be published soon. Hint: it seems that
90° opening angle (ca 10.5 - 11 dBi) for a f/D = 0.6 dish is
suboptimal. A smaller angle seems to deliver more SNR.
Post by g0mjw » Tue May 21, 2019 5:37 pm
That is as expected. The lens is for dishes with F/D of 0.6 to 0.7. It is not for 0.4 f/D - look at this web page https://rfantennas.wordpress.com/author/hb9pzk/
Willi indicates the open waveguide is good for 0.3 so you might benefit from a small lens but not a rocket and probably not much.
g8lce
Post by g8lce » Mon Jun 03, 2019 9:09 am
I bought a poty kit that comes with a PTFE lens. I found the lens I took off the original LNB worked better than the kit one in my situation. So it may be worth trying the original lens if you have bought a poty kit. I put the original 'waterproofing cover back on with some sealer over the top of it. I may remove that when I make a waterproof cover for the whole poty.
