Es HailSat 2 location
Re: Es HailSat 2 location
I have a 65cm Solid offset dish but it sounds as if its going to be a bit marginal. If I treat myself to a 1M dish, are there any RF performance benefits from a solid vs mesh dish? Clearly a lot of extra windage to deal with and about a £10 price difference. Buy once and all that.....
Hi you would be far better with a solid dish and personally i would go for a 1.2 theirs not much difference in price, winds over 50mph a mesh dish has the same wind load as a solid .radiogareth wrote: ↑Thu Jan 31, 2019 9:27 amI have a 65cm Solid offset dish but it sounds as if its going to be a bit marginal. If I treat myself to a 1M dish, are there any RF performance benefits from a solid vs mesh dish? Clearly a lot of extra windage to deal with and about a £10 price difference. Buy once and all that.....
I've seen lots of 110cm dishes advertised but not any 120cm. Any suggested suppliers please?
73 Barry G8AGN
73 Barry G8AGN
Hi Barry this company do them https://www.satellitetvshop.co.uk/1.2m-satellite-dish if you google you will find cheaper models, the used market is a good place to look as well i would recommend trying to find a 1.2 channel master there a great dish last forever eBay gumtree is a good place to look.
https://www.ebay.co.uk/sch/Satellite-Di ... llite+dish
I receive Es'Hail with no problems (after extremely fine tuning of the dish position) initially I used an 80cm sky dish with a standard very cheap LNB from Ebay and a minitiouner.
I have also received it very well on a cheap £20 satellite receiver (also from Ebay) using the same LNB and an ADX-Plus up converter which adds 500MHz to the IF frequency and brings the LNB output within the tuning range of the receiver.
Not that the ADX-Plus frequency is not very accurate and will need to be measured before programming the satellite receiver. I have two ADX's one on 498.7MHz and another on 495.1 Mhz - this is near enough for wide bandwidth broadcast TV but not accurate enough for narrow bandwidth TV.
When I set up the transponder I entered 10492.5MHz + 495 = 10987.5MHz for the frequency and symbol rate of 2000
you might have to play with the polarisation - I turned the LNB through 90 degrees for the minitiouner.
