Receiving beacon but nothing else
g8vpg
Re: Receiving beacon but nothing else
Post by g8vpg » Tue Feb 26, 2019 3:32 pm
G4WIM has reported good results using the Technomate TM1 LNB from Amazon at £7.99. I have ordered one to try. Technomate do not actually say PLL in their spec., but just say high frequency stability. However if it is producing a T9 morse tone on the nb transponder, it must be PLL.
73 Shaun.
G4WIM
Post by G4WIM » Tue Feb 26, 2019 4:48 pm
Yes the TM1 is PLL with a 25MHz xtal ref as I can just about detect the 25MHz ref signal leaking out of the F type connector.
Regards Tim
M0DHP
Post by M0DHP » Tue Feb 26, 2019 5:02 pm
M0NRD wrote:
Tue Feb 26, 2019 3:06 pm
You say the LNB is mounted horizontal, but have you added the slight clockwise (looking at dish) skew needed? I know looking on the SDR I optimised for the WB transponder by adjusting to get the strongest beacon and noise floor.
Yes, I've tried adjusting skew and the forward / back position of the LNB in the mount - no change :(
I'm waiting for a new LNB and will also try a different, faster laptop. All that leaves is my MT, but that's been proven extensively on terrestrial signals.
What's frustrating is I can decode the beacon no problem, zero errors and MER 4.
Post by g0mjw » Tue Feb 26, 2019 5:50 pm
I would be surprised if a DRO LNB had the phase noise performance necessary for 333ks, You really need PLL. No need to lock it for TV though.
M0DHP
Post by M0DHP » Tue Feb 26, 2019 9:12 pm
Thanks, Mike. The new one I've ordered is PLL, so will report back once it's arrived.
G7JTT
Post by G7JTT » Wed Feb 27, 2019 5:25 am
Have tried listening to a narrow band signal ? Just had an issue with my set up and found the LNB to be at fault. When I looked at the CW beacon it was all over the place like the PLL couldn't lock. Changed LNB and all is ok now.
John
M0DHP
Post by M0DHP » Wed Feb 27, 2019 10:11 am
Not yet, John. I've got a bias tee on the way and then I will try that.
Ray
g8nop
Post by g8nop » Fri Mar 08, 2019 11:08 pm
Ray, did you get any joy with the new LNB? I have the same trouble as you (great beacon pictures and nothing else) and with two different PLL LNB's. I know I'll crack it soon, but it's soooo frustrating.
M0DHP
Post by M0DHP » Sat Mar 09, 2019 6:48 am
Not had a chance to try it yet. Will post here when I do, but it may be a couple of weeks.
PE1BR
Post by PE1BR » Sat Mar 09, 2019 12:14 pm
I had the same problem in the beginning.
The problem was my Offset frequency was not exact enough so I didn't receive the smaller signals.
Playing around with the Offset up and down on A smal signal til you get A lock may help.
