BATC WEB SDR Cornwall, the old Problem with the cookies
df6yc
Post by df6yc » Thu Feb 05, 2026 3:32 pm
Hi Folks,
the real wellknown problem is again on the road.
The web sdr greet with this not nice message:
"Your browser is trying to send too many cookies, this doesn't work with the websdr application. Please click here to clear your cookies and refresh the page"
I truely believe that this is not the problem of my browser, in the past it was often a problem with software from the web-sdr or something like this.
Please have a closer look to this problem.
Thank you very much
DF6YC, Michael from Germany, JO41JW.
G0NMY
Re: BATC WEB SDR Cornwall, the old Problem with the cookies
Post by G0NMY » Fri Feb 06, 2026 7:11 pm
Im not sure which browser you are using, I use firefox,and I had the same issue a few months back.
I didnt want to delete all my cookies as this caused login problems with other webpages I was also active on.
I found by opening the eshail web page in a new Private Window stopped the problem as no cookies were set in the private window.
Hope that helps
73 Mark G0NMY
http://www.g0nmy.blogspot.co.uk/
¡ʎɐqƎ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq I ǝɯᴉʇ ʇsɐl ǝɥʇ sᴉ sᴉɥʇ
G0NMY
Post by G0NMY » Fri Feb 06, 2026 7:15 pm
Scrub that idea I just tried it and the private window method no longer works.
Oh dear :( :?
WiSi-Testpilot
Post by WiSi-Testpilot » Fri Feb 06, 2026 7:43 pm
Same problem here. I've also been wondering why there's so much activity on Roberto's website.
http://websdr.is0grb.it:8901/
By the way, it also displays images that were sent via KG-STV and HS modem.
73 Wilhelm DG2YK
G0NMY
Post by G0NMY » Fri Feb 06, 2026 8:14 pm
73 Wilhelm DG2YK
Oh yes I forgot about Is0grb's web sdr page.
good call
G3VZV
Post by G3VZV » Sun Feb 08, 2026 10:51 pm
Hi All,
The cookie problem has now been fixed.
Also the 2 metre receiver on the VHF WebSDR has regained its proper sensitivity - the 'MRF preamp is now being powered again
Thanks Phil:)
Graham G3VZV
df6yc
Post by df6yc » Mon Feb 09, 2026 8:20 am
Hi Folks.
thank You for the fix of the problem, I hope this results in a final fixing and the problem does not occur any more.
Michael - DF6YC
