UDEV ? User permissions and all that.G4GUO wrote: ↑Mon Jul 29, 2019 7:36 amWell Tim,
I did write an application for Express that runs on the Jetson but it doesn't work properly and I have no idea why.
I ran it on a standard Intel Linux machine and it worked but not on the Nano. (Go figure).
https://github.com/G4GUO/datvexpressSink
- Charles
MRF24300N performance at high power
Re: MRF24300N performance at high power
Sadly not. If I put it into a tight loop sending NULL packest it does in fact send null packets. But if I then try sending video I get dropouts.
If however I install the application on a Intel PC running Linux and stream video from the Jetson to it all is fine. It may work on a PI but as I don't
use PIs I can't test it.
Unfortunately I don't really have time at the moment to look into it as I am busy trying to figure out how to get the MPSoC on the ultra96 board
I have to read an LVDS DDR interface (steep learning curve for me at least).
- Charles
- Charles
