POTY (or MJW patch) cover
Post by g8gtz » Thu May 02, 2019 10:27 am
I have found that Waitrose flapjack containers are just the right size to go over the MJW patch and do not affect RF performance.
I cut a 22mm hole in the center of the lid and then a long slot so I could drop it over the 22mm pipe between the back plate of the patch and the mouting bracket. I then cut a slot in the actual container to accomodate the Tx feeder and used a cable tie to secure the remaining flap to the tx feeder to secure the cover whiich just clipped on to the lid as normal.
BTW - other suppliers are available but not tested!
Enjoy both the flapjack and the container :-)
PS sorry about the uncorrected iphone sideways pictures :-(
IMG_5273 (Small).JPG (89.91 KiB) Viewed 9769 times
IMG_5274 (Small).JPG (138.74 KiB) Viewed 9769 times
2i0jmt
Re: POTY (or MJW patch) cover
Post by 2i0jmt » Thu May 02, 2019 1:27 pm
Looks very interesting!
Please excuse my ignorance, as I'm very new to satellite work, but is the purpose of this solely to protect the antenna from the rain?
And the real question is, does it work with M&S double chocolate minibites?! :lol: Those I could eat for days.
G1BVI
Post by G1BVI » Thu May 02, 2019 1:37 pm
Hi 2I0JMT
The object is to protect the patch from the rain.
Any enclosure that is not affected by microwaves is suitable.
If you have a Microwave oven put your chosen enclosure into the microwave and blast it on full power for a minute (without the chocolate contents)
If the plastic melts or distorts then you know not to use it.
Nick
2i0jmt
Post by 2i0jmt » Thu May 02, 2019 1:41 pm
Thanks!
Post by g8gtz » Thu May 02, 2019 3:34 pm
2I0JMT
I don't know if M+S chocolate bites would work but worth a try even if not in the interests of science.....:-)
Post by g0mjw » Thu May 02, 2019 3:36 pm
That's neat. I went for a more technical approach:
It needs replacing occasionally. I might try Noel's solution but what to do with the flapjacks?
Edit - Action shot
2W0ODS
Post by 2W0ODS » Fri May 10, 2019 5:07 pm
Reminds me of the blank CD/DVD cakes I use for keeping the water off aerials I make.
They come in different sizes, not tested them above 1500MHz however!
Post by g0mjw » Sun May 19, 2019 4:32 pm
I pass Waitrose on my way back from Dunstable Downs, so I went in. There is a two-radomes for £4 offer on at the moment, so I now have one to try and a space for when I make a mistake.
g7ntg
Post by g7ntg » Mon May 20, 2019 8:18 am
I use a hemispherical acrylic dome easily obtained from ebay ; Clear Plastic Acrylic Craft Ball Sphere Baubles For Christmas Wedding Decoration.
these are sealed with self amalgamating tape stretched around the periphery.
they have no measureable effect on signal strength at either frequency
