not sure what figures you are referring to but for all our purposes, there are only a few really important ones.
Lat/Lon should be ideally 0/26E, AZ/EL is probably obvious. Speed is given due to the geosync nature. All the things like Right Ascension, Declination and local sidereal time are not relevant for geosync satellite.
Es'hail-2 on the move.
Re: Es'hail-2 on the move.
The 11.205 GHz beacon signal has got a lot stronger here and I am aligned on Badir-4 at 26E, so I think it's now in it's slot. It's fully quieting in FM bandwidths now. Every so often it has a few more "CW" carriers which I take to be ranging signals. Ignore the small carriers near the centre, they are local spurii.
- Screenshot-2019-01-02-220927.jpg (839.19 KiB) Viewed 4490 times
Judging by the N2YO.com figures, over the last 12 hours or so, there appears to have been manoeuvres to insert the satellite into its slot, which I believe to be around 26E, although it could be closer to 25.5E to match Eshail-1. For stabilisation, ie arrival on-station, look for a longitude that appears to not change by more than about +/-0.05degrees over time. According to N2YO.com, as of 06.45 GMT, Eshail-2 was at 25.86E.
There is currently a 16kHz ranging tone in use, which is a coarse ranging tone. The flight controllers have also used 100kHz during IOT, which is a fine ranging tone. I wouldn't necessarily draw any inferences from which ranging tone may be in use, but 100kHz more often may indicate that they are nearer to target location.
However, arrival on-station doesn't mean that the satellite has finished testing, which may be ongoing for a while and any official availability may take some considerable time yet.
73 Jen
73 Jen
according to Amsat-DL , the final position of Es`hail-2 will be at 25,9 degrees East,
so it is nearly at the final position.
