New Factory Tuned Duplexer Fitted by John to GB3ET,
Due to Switcher Fault We have re-directed digital output to IO92GQ GB3ET Link,
I hope to travel down to ET in the next month to refurbished system...
Going to IO92GQ GB3ET Link on repeaters page,
If you see the Blue Screen with invite to Tx, have a go as Rx (1249 2M/S) performance very much improved.
GB3ET Stream will be back on soon (off Air Stream Yagi changes), and then 1249 analog input available, same improvements.
Peter
New Duplexer GB3ET
Re: New Duplexer GB3ET Update...
We are Streaming over 4G from site to IO92GQ GB3ET-Link.
Steve M0SKM Dunstable was giving his new P.A. a try out toward ET near Banbury.
I managed to get this frame dispite my flakey 4G stream.
Looking forward to his return, and I can update picture
And here it is!
Peter
And here it is!
Peter
- M0SKM-1.png (382.58 KiB) Viewed 20316 times
- M0SKM-2.png (194.26 KiB) Viewed 20316 times
Took the big PA off Peter and tried 18Watts from the Mitsubishi brick, you'll be pleased to know I can still access ET from Dunstable. I've also found a solution to the Portsdown rebooting when the beam comes round your way, see picture. Changing modes is slightly awkward now.
73 Steve
73 Steve
- Ikea_faraday_cage.jpg (260.74 KiB) Viewed 20252 times
Hi Steve, M0SKM,
Sorry I missed this post, better late than never!
Hope you didn't have to queue?
2E0XAY, Steve in Leiester now getting in, added rain storms recently for best performance?
Thanks for update.
Peter
Picture from Steve's shack in Leicester.
Thanks for update.
Peter
- 2E0XAY Testcard.png (200.84 KiB) Viewed 20125 times
- Picture from Steve's shack.png (227.65 KiB) Viewed 20129 times
No longer receiveable in Malvern IO82UC. Previously receiveable with a MER of ¬5dB
I did receive it in when portable in IO91BV82 on june 21 2020 with a MER of 9dB
G4FRE
G4FRE
